Sticker cutting service
We can get pretty much any colour :nod:
Best way is if you've got something the right colour you can slap in the post, then we can match it up with the swatches we've got here.
I'll get some etched tests done today BTW :)
ok, here's the etched vinyl test. It's basically an opaque film with a slight metalic in it.
It really really stands out on a black car, it'd look a load subtler on a light coloured car as you can see on the bottom pic where it goes across the white.
I quite like the effect, but it's not what they used on the DriftUnit car. might give it a go on the windows.
Thats gonna work nicely on a light car :nod: but not the effect I was looking for, My guess is its satin black vinyl they are using - any chance you have any of this? :D
Actually looking again thats gonna look pimp on a white/light silver car - take a look at where the 'D' overlaps the white vinyl you have on the car - looks like its 'ghosted' and looks pretty pimp :nod:
Matt black is readily available, but satin finish is going to require a bit of a dig around. I'll see what I can come up with....
For give my ignorance but whats the difference between matt and satin and would matt do the trick?
That etched vinyl looks sweet - I'm thinking it'll look sex on my white car...
Is it visible from any distance back though, or just when you're really close up?
Jord, Matt is not shiney, or at least only slightly shiney. Satin is kind of half way between that and glossy. I reckon because it's vinyl, the Matt will do the job.
Kiruji, I'd like to know too, but for some reason we only own dark coloured cars at the moment.... :rolleyes: If you PM me an address, I'll get one slapped in the post to you so we can all see what it looks like :thumbs:
Cool, so can you sort me out with the previous order in matt black then pls? Thats 2x60cm outlines in matt black, 1x50cm outline in white and 1x30cm outline in white. I presume matt is cheaper than frosted?
No probs Jord, I'll get some matt black in. Should be here Thursday now, can have stickers with you for Friday AM all things being well :thumbs:
yup, all here, just running off some 60cm ones for you as it happens :)
For the 30cm ones, they get really thin and spidery that small the lines are only a couple of mm thick, do you want the standard 30cm ones instead?
Hmm, not sure, would it look daft if the outline was made thicker?
Oh I should probably mention I need the one for the drivers side to be mirrored! :rolleyes: Sorry if its too late! :o
So its -
1x 60cm outline matt black
1x 60cm outline mirrored matt black
1x 50cm outline in white
1x 30cm outline [or whatever looks best] in white
