Phil said:
that is the bollox and exactly what im after i will be looking your way soon for one of these for my R32
Phil said:
raff said:could a mocal thermostat be plumbed into this afterwards, just for driving on the road the oil could get too cold i think?
in the winter if it's proper cold and you're not driving hard and just pottering around, it can be an issue if you don't have a thermostat fittedandy bird said:do you really think the oil could get too cold just driving? surely not
yes, exactly that. It ensures that if the oil temp is less than 80 degrees C, it won't go through the cooler.Rob-S13 said:what does the thermostat do? bypass the cooler?
yup, we've specced it up so the oil lines that would normally go into the cooler go into the rear of the thermostat and you then run short lines from the front of the thermostat to the cooler.andy bird said:can you add that into the kit?
yup, it will fit fineTalat said:Just to double check before I order - will this kit fit a red top SR ?
Cheers,
T.
