Thailand SR20det powered BMW build
Thanks much, finally starting to find a bit more time to play with her again so i'll have some more updates soon!
recently had some time to add a little strength and caster adjustment to the front strut mounts.
welded in a bit more metal today and test fit the manifold/turbo (turbo not clocked yet). Also had to weld in a bunch of shi*t including right hand side front lower control are mount as the original threaded piece inside the frame rail was destroyed.
*replaced with better picture in the next post*
More metal...
Front strut towers
Tubes to front frame rail
Tubes to lower frame rail under drivers/passengers feet. *still need to add gussets to a few places on these*
Repair/re-enforce/replace frame rails
Added "sub frame connectors (these basically run wheel to wheel (front to back) along the pinch welds and have a few cross bars) *will be incorporating trans mount and drive shaft hoop in the cross bars*
Sheet metal patch/re-enforcement **as you can see in the pictures rear of the front wheel wells still need some sheet metallove**
cool build man, some nice fab work, im currently finishing my sr e30 project, not gone to this extreme tho....top work
E34 complete subframe swapped in along with rear coilover set up.
I also had some time to start on the cooling system, still have to add a few breather fittings/lines before she's complete :)
Itching to get back to Thailand to get this e30 on the track!
Anyone want to by an RB25 E36!? its in Bangkok (was is my Thai daily driver) could be a perfect street/track car for Thailand (free indoor storage for 1 year in bangkok, this is a vacation drifter dream!) Love this car just need to use the funds to finish up the E30 and a couple other projects.
https://brewedmotors.com/blog/rb25-swapped-bmw-flex-fuel-aem-street-car.html
Dude your build is so epic (y)
Can't wait to see more of this, and that e36 is mad please tell me theres a build thread for that somewhere!
