bigdave z20
A regular turbo supplier can probably get you one but it won't be cheap like the ex test ones that compressor racing sellWhere can a man buy a Holset he351w new???
It’s a M54B30 so a 3.0ltr engine. Of you look at pictures I posted you can see how the WG is plumbed back into the 3” downpipe, and yes a 4” just isn’t really possible.
What's further down the exhaust system? Any mufflers or catalytic converters that could be partially blocked?
So what's the engine doing and when?
You say choking, is it not making more power on the dyno or struggling to rev to limiter?
That’s a very good point, I only tested to 10psi as only had 1 clip large enough and the test rig would pop off at anything over that, I’m actually in the garage now with another clip the right size and going to test to 20psi.
I have an AEM TRUEBOOST controller, what I’ve found is by increasing the duty cycle in turn the spike increases also, and obviously I don’t want to break this engine as it’s still in the mapping process.
Using softer springs and increasing the duty cycle I found boost still dropping off in the higher RPM range as the WG was getting forced open.
The controller is installed correctly and the wastegate has no leaks in the top and a slight leak in the bottom from the bush the valve goes through, this leak is only present when parts are cold, once upto operating temps it is almost completely sealed.
Needs a genuine gate before anything else then.
Can't see it choking probably just the wastegate spring will be weak, you could try the stiffer spring and see if it holds boost up top.
Hey man, with regards to your boost spike issue - the tru boost manual says to set the "SPR" value to 3PSI less than your spring.
give it a go
Sussed then. Post up the results when she's had a beating on the rollersNot finished the wastegate pipe yet but the plan is to vent to atmosphere. Mainly for noise. May consider plumbing it into the exhaust if/when I get fed up with it.
