My beloved Sil80 is for sale as i no longer have the funds to keep it going and need to save up for a house!
Heres the spec, it was bought off a chap from Driftworks last May.
1992 K Reg UK S13 with Silvia front end.
ENGINE:
zenki S14 SR20
S14 gearbox
zenki S14 ECU and CW SPL engine harness
HD Stage one chip
S14 rad
S14 AFM
Z32 fuel filter
NGK Iridium Plugs
Walbro fuel pump
SARD anti bubble tank
Earls custom oil feed and F1 spec oil return hoses
Earls water blanking plugs
S14 HKS frontpipe
MR Tuning custom decat pipe
Blitz Nur spec catback, modified by WMS to sit higher.
Poly exhaust hangers
Hybrid Turbo Technics T28/T3 turbo
Blitz LM filter
Hybrid IC mounted infront of rad
Cusco engine mounts
Uras gearbox mount
ORC 409D single plate clutch and lightweight flywheel
CHASSIS/STEERING:
Stainless steering bush
Nismo Power brace II
Section pillowball tension rods
braided brake lines all round
Earls custom clutch line, clutch damper bypassed and removed
BRAND NEW 'BOA CHANG' COILOVERS 5/4 SPRING RATES - A MILLION TIMES BETTER THAN THE OLD D2'S ON IT.
Apex rose jointed RUCA's
DW anti bumpsteer rod ends
Tein steering arms
DW rack bushes
rear strut tower bar
poly subframe bushes
cusco MZ diff set to 2way atm
diff oil cooler and pump removed
ABS removed
15x7j -2 offset SSR mesh (rear)
15x7.5j -6 offset SSR mkIII (front)
195/55 toyo T1R's on the front
205/50 Eagle F1s on rear with decent tread and a BRAND NEW set in my garage.
BODY:
aerial removed
despoilered
dewipered
black roof
S13 silvia front end
OEM aero skirts
rear arches rolled
front bumper support removed
180sx rear light panel
Sprayed in black and white by me and my mate so not the best quality!
INTERIOR:
sparco corsa bucket seat
bride FG rail
momo corse steering wheel
Garage Rippledrift steering wheel spacer
Dildo gearknob
cusco spin turn knob
modified handbrake cover
sparco 4 point aircraft buckle harness
180sx dash cluster
cd player and 1 front speaker, 2 6x9's in the rear
completely stripped, all soundproofing gone with front carpet refitted
Leather trimmed passenger seat
apexi 60mm EL mechanical boost gauge
Greddy 60mm electrical water temp gauge
Security:
Clifford Concept 650, 'nuff said!
Bad points:
Turbo has a tiny crack in it. Makes a shuffling noise coming off the gas. No smoke wotsoever.
Crank pulley oil seal is leaking slightly, got a new oil seal but not fitted!
NO TAX or MOT. But can be sorted when there is a buyer.
£2500 ono
Any questions feel free!
Can anyone host the pics for me?
Cheers
Kenny
