Unfortunately, not so much has progressed with the e90 during this year as I hoped.
The motivation has been on the bottom and I have started to plan building a new house as well as lots of traveling in my job so the project has suffered.
It is the last time that it has begun to be sanded properly to prepare it for paint.
Went and bought me a 525 TDS from a colleague cheaply.
It had been standing for a few years since it was last started so I picked it up and changed some parts to get it started and then sold it to a friend who will take the drivetrain and put it in a Volvo 760.
Helped a friend move his ice beater between 2 garages. It became a bit ugly last season.
I went over to Riga to watch the DMEC competition which took place there in August.
An incredibly well built E92 (eurofighter) that did not qualify, this one has been run in Formula Drift and has a MAST Motorsports V8 with about 900 N/A horses.
The yellow S15 is run by a Russian who was invited as a wildcard to the competition, finished 2nd and runs a 2.2L SR20 on about 800 horses and original cable handbrake.
Test mounted my clutch which is for 135i / 335i.
I had to grind out some inside the gearbox for clearence and I had to shim the starter motor about 20mm from the surface towards the gearbox as the newer alu blocks have a molded distance there.
Went to my buddy and borrowed his garage over a weekend to reinforce my rear attachment points and to start changing all the bushings in the subframe to yellow strongflex.
Made a new batch of e34 adapter plates.
These are made to bolt the e36 / e46 front beam onto the e34.
I recently sold 6 sets to the US where some will converting their cars.
Finishes this update with that I during black friday couldn't resist to shop
I bought a Turbosystems HTX4064B1 which will be exciting to test.
64mm in and out, double ball bearings and stainless steel exhaust housing.
