Ben, that's a very close match to what I have in my head! Hoping to pop down to a local paint supply place local to me in the next week or so to try and view some paint chips so things can get moving
(Oh, and he runs a Red Bride Zeta III, so I'm instantly biased
Since the last update, the Vibratechnics engine mounts turned up
The quality of them feels unreal and unlike any other engine mounts I've seen, but time will tell whether they are any good or not. I opted to go for the "Drift Max Pro" or the Competition version as the price difference was negligible, and a friend used to run them and appeared to praise them.
The engine mount brackets on the SR were looking rather tired and quite frankly, ugly. So a quick freshen up was required; with an initial cost of Zinc primer after being rubbed down and degreased.
I settled for a quick coat of Satin Black as opposed to a metallic silver I had lying around, more so for that OEM look and aesthetically breaks the engine up a bit.
Whilst I was fitting the engine mounts, it was a lovely day so opted to grab a quick photo of the SR, it seems I can't quite get enough of it!
Before the car gets painted, I wouldn't mind getting the position of the fuel pump and swirl pot finalised, so any cutting can be done prior to painting. This will be my main task for tomorrow amongst further prep work, but from the initial looks an S13 fuel tank location and direction of the inlet/outlets makes it a bit trickier to ensure the lines are free from any kinks.
So I finally bought the fuel pump, where I have opted to run a tried and tested setup, in regards to a Bosch 044 as an external pump, where I'll run a fresh Walbro 255 or similar as a lift pump. As with most things, the difficulty with the Bosch's is the shear number of fakes floating around, and with something as important as the fuelling, this was something I really wanted to ensure a genuine part was used. Luckily, Torques UK came to the rescue being a Bosch dealer, so it was an brainer for me, considering their knowledge of AN type fittings, I'm sure I'll be place another (yet expensive!) order in the future for a number of fittings. Anyhow, this promptly arrived;
Bosch 044 with an AN -8 inlet to match the swirl pot, with an AN -6 outlet to match the SR's fuel lines, perfect! Oh, and got a snazzy cradle to hold the fuel pump
Updates will remain a bit slow for the next couple of weeks whilst prep continues, but I'm hoping progress will become alot quicker once paint has been laid and final fittings can occur!
