I'm going to look at 2 MX5s tomorrow with the idea of hopefully buying one of them and using it as a drift car. One is a mk2 and one is a mk3 (I know, not really much point getting a nice mk3 one just to drift it... but hey, going to look at it anyway). Both are 1.8 litre and I believe neither of them have an LSD. EDIT: it turns out the mk2 one might have an LSD as it is an "Icon" model... but the jury seems to be out on whether or not that definitely has one in UK spec.
So first question: Without doing anything to the diff, will this thing be able to drift much at all (on a wet track) ? I'm used to an M3 where you can easily spin up the rear tyres just by flooring it, but I'm conscious that it's not going to be that easy in an MX5. Bearing in mind I'm a beginner, is it going to be very difficult to get much of a drift going with a completely stock MX5 (again only talking about in the wet) ?
If I really do need to do something to the diff, I know I could just get someone to weld the diff but it seems like the more "proper" option is to get an LSD fitted? Anyone got any suggestions on what to get or what to avoid? I found this one: Kaaz LSD for Mazda from Driftworks.com but one thing I'm not sure about is in the chart there the latest model MX5 it lists is a 1998 onwards model, so if I did get a 2006 mk3 would that not fit? or is it just that literally any model from 1998 onwards has the same system and this LSD will fit it fine?
Thanks
Chris
Thanks
Chris
