Stavros
Active Member
i wonder if any of the us spec Kompressors came with a lsd?
Nope, none did, not a single W202 model came with a LSD, even the AMG cars
I have found a few solutions so far, none particularly cheap and simple though...
Just been digging the net, very weak for info, did notice the 'all 2.3-16 valve 190 models are fitted with a Limited Slip Differential as standard', wonder if it would fit?
Dont know if this helps
1995 C36 has LSD? - Benzworld.org - Mercedes-Benz Discussion Forum
Thing is, ive also heard various things. Far as I can tell its not as simple as a single fuse, in fact ive looked, if there was a single fuse to pull I wouldve ages ago.
Ive heard instead you pull one of the ABS wheel sensor plugs out, which disables all the aids. Which is good and easy.
BUT also, depending who you believe...
It is not easy reversable, ie you try plug it back in and the light stays lit etc until you get the ECU reset with the plug-in thingy.
OR it does the above and also puts it into limp home mode.
Fuck, I heard if you change the diff ratio to one off another car, due to the ABS sensors that work off the diff, that puts it in to limp home mode too.
And the above isnt ideal. I know a lot makes it go in to limp home, as I made it do it myself with various things I tried.
BUT if it does and doesnt automatically reset, which is what some say when you do the ABS thing, I a bit reluctant to try it.
Washed the car yesterday for the first time in months. The arch rolling and winter salt has caned the front arches a bit, my fault, but fuckit.
yeah they have silencer ports on them mate, either side of the triangle the air gets forced out, welding them up will increase efficiency and noise, a plus in my books
im gonna buy a spare and port that, and then just swap them over, should net an easy 20 bhp just porting the charger.
Im gonna keep my standard diff for now, as when i go home its an 800 mile trip, so costs me about 160 quid in fuel as it is, ive fitted a button to turn the charger off in the hope i can increase the economy by just a few MPG when taking it easy on the m/way.
