Tertil
Hello all. After around 18 months spend in Europe for the sake of travel, I'm a week away from flying back to my home city of Christchurch, New Zealand, to continue with a lifestyle of what I love most in the world.
I have sent some money home and purchased a rather rough C34 Laurel, which is being shipped across the country and should be arriving home around the same time as me, one week from now. The body is rough as guts and it has a horrible, horrible body kit and 'drag style' wing on it, but every other aspect of the car is complete, and competition spec. It comes with almost all the bells and whistles I have dreamed about having on my next slider, and has twice the balls of any other slider I've owned (two R32 sedans and an FC), so I am super excited to get back and drive it.
This car will be 90% street driven, with a track day maybe every 2-4 weeks, as here in Christchurch we have hills and industrial areas where drifting can be taken to the streets without putting any innocent people in danger...
The mod list is as follows:
RB25DET S2
R33 'Big Box'
Exedy clutch w/ lightened flywheel
Link G4
Extensive roll cage
Bride buckets on adjustable rails
Monza five point harnesses
Genuine GReddy intake
DSR430 turb on a stainless manifold
Tial 38mm wastegate
800cc injectors
'500hp' fuel pump
Genuine HKS BOV
Nolothane bushes everywhere
The usual arms
D2 coilovers
17x9 and 17x10 DTM Drift rims
De-tarred body
Momo wheel and quick release boss
Rack lock spacers
Clear cam cover w/ HKS belt
Light weight alloy fan and alternator pullies
This setup has seen 301kw @ 18psi, but currently has 240kw @ 14psi and a low boost setting of 10psi. The seller has advised me that although it runs fine, it hasn't seen a lot of use lately and could do with a re-tune. Therefore my first plans are a compression test, coil pack test, new plugs, injectors sonic cleaned and flow tested, and then go for a re-tune with at least a high boost setting of 18psi and a proper conservative low boost setting for street cruising, with proper fueling for fuel efficiency, not that it will ever particularly have that.
After enjoying that for a while I intend to convert the front to non face lift, rip the horrid kit and wing off, panel and paint the outside, inside and underneath, DW knuckles on the front, and some nicer wheels. After all is said and done, it should look quite similar to what is considered by many as the coolest C34 build on the planet, Takuya's LOWBRAIN C34. I hope ya'll enjoy the thread as the car is developed over coming months.
RB25DET S2
R33 'Big Box'
Link G4
Extensive roll cage
Tial 38mm wastegate
800cc injectors
'500hp' fuel pump
Genuine HKS BOV
The usual arms
D2 coilovers
De-tarred body
Rack lock spacers
