Everything kind of fell together with the ammo box, but first up a shot of the LED light strips in the footwells and boot:
Next disassembling the old bass tube was done in 10mins. 4x screws and the subwoofer popped out, 6x screws and the amp was out as well and the port slid out with a bit of a tug.
Measured it up and the sub fitted on the rear perfectly, offset as planned, and the amp & port next to it. Traced out the holes required and took to it with the jigsaw. Mocked everything up and voila:
Now as part of making it fit between the RHS rear strut tower and the battery box I had to remove two bits of wood on the (now) bottom. These weren't overly structural but were where the rope handles anchored. In the end i had two bits of rope leftover on each end, so figured i'd try joining them. Grabbed 6" of adhesive heat shrink and it looks pretty sweet! (can see it on the top pic)
Then it was as simple as putting it in the boot and wiring it up
Have tested and works amazing. Couldn't be happier tbh
In other news i've been helping a mate +T his FL S14 manual SR20DE. We were originally going to +T a PFL he owns as well, but it's rougher yet has more goodies. So on Sunday we pillaged the PFL of it's big alloy radiator, twin thermos, strut brace, engine damper and soon it's HD clutch. We tried to retain the AC in the PFL but elected eventually to bin it.
We used my spare 550mm x 230mm intercooler flipped upside down with 2.5" tight 90deg joiners in a high mount setup. Relocated the loom from under the radiator support panel to run along the bottom chassis / tension road support brace instead, which gave us the space to put the intercooler right up the top. A bit of massaging with the hammer so the joiners fitted and we were golden
The radiator sits in factory position and joiners clear no problem. Connected the thermos to the AC wiring and they kicked on at 95deg as per factory, however driving it on the open road with no viscous and no fans going it sat at 75deg on the open road (go the Fenix radiator!). Found a suitable bit of alloy piping for the cold side, drilled & tapped a hole for the idle control, threw the AFM on the intercooler's hot side joiner and it fired up and drove (and did a burnout) no problem lol
Next steps are swapping in the HD clutch, battery into the boot as it's a tad tight up front, swapping the pump for a Walbro 255 and hard wiring it, fitting an SAFC, swapping in a rail with 370cc injectors, drilling & tapping the block for the turbo oil drain, fitting a braided oil feed (T'd off the oil pressure switch port), factory turbo manifold w/ T25G, 3" exhaust, finish hot side piping & turbo intake, swap plugs, retard the base timing 3deg, fit my AEM wideband and road tune it at 10psi. Obviously full process is more in-depth than that but I'll try document it here.
Between the two of us we've got spares coming out of our ears so have pieced everything together quite easily and I'm keen to give road tuning a go
