In other news, I've been doing work on the interior again
What started this bit of work was breaking the glovebox handle. This happened because i had the heater controls and the mini 4 channel amp in there, which just put too much load on the latch.
So one of them had to come out, and i chose the hardest of the two. What made this possible was an extension loom that popped up for sale for $30 which got me thinking about what an old mate did with his R32:
https://dsd32.wordpress.com/2012/03/04/doing-work/
https://dsd32.wordpress.com/2012/10/02/plugging-a-hole/
So aim was to put it in the arm rest center console. Once the extension loom turned up i realised it only extended 2 of the 3 necessary plugs, so without a second HVAC control unit to disassemble i elected to cut the plug off the factory loom and extend it.
12 wires were needed so i grabbed 2m of 7-core trailer wiring. Two lengths of this would give me 2 spare wires for anything else in the future.
Netflix and wire
What made all this waaaay less daunting was an auto wire stripper and these little buggers called solder heat shrink butt connectors.
https://www.aliexpress.com/item/50p...s-with-Soldering-Sleeve-0727/32825723124.html
The red ones are a perfect size for your standard size wires, but the white ones can do it at a pinch. Am all out of red ones already so have just ordered a hundy pack of them.
Sleeved the trailer cables with braided sheath, and sealed the sheath to the cables with some adhesive heat shrink (has glue that melts on to make it permanent).
At this point i wanted to find out why my temperature control had always been via pushing/pulling a primitive cable hanging out the side of the dash.
I then discovered the presence of 3 different S13 heater control units:
The manual cable operated ones, where the heater mix door is operated via a cable connected to the heater unit
The auto ones, where the heater mix door is operated via a rod connected to a motor
The digital ones, which are an unknown (possibly operate the temperature via same method as the auto units)
I have an auto heater control unit, and a manual heater core. Hence the presence of the cable hanging out of the dash. I either needed a manual control unit or a mix door motor and rod. With the move to relocate the control unit to the centre console, space at the back of the unit would be limited, so getting a cable to fit would be tricky. Also the extension loom i bought would then be useless as the plugs are different between the manual and auto ones. Luckily another two-tone owner had a spare mix door motor and rod and has just popped it in the post to me
So cracking on, made a template of the back of the heater unit to trace into the bottom of the centre console so i knew where to cut holes for the plugs. Then made a simple bracket to hold it in place and fitted an M4 rivnut into the centre console and she's in there
Got it all reassemble last night and tested up well enough. Plan is to make a panel on top how Dan has done, but want to hold off until i can confirm there's nothing else i want to fit in there.
I have a replacement latch for the glovebox so will fit that once i decide what to retrim my glovebox and door cards in
