Thanks guys
Bit of an update from last time. Got the BN front painted
Made an oil cooler duct that fits to the bumper
Then fitted water sprayers to the radiator and oil cooler
Because it just uses the factory windscreen washer bottle & pump (that i relocated to the boot) I added in a manual switch using an old 12v feed from when it used to run an external fuel pump. Then spliced the windscreen washer water line up the front and added a couple of manual shut off valves, ran hosing to the front and hid the sprayers behind the radiator support uprights, terminating it with a single sprayer for the oil cooler. Made up a little clip that bolts to the intercooler hose clamp for the oil cooler sprayer.
Then went to our summer matsuri which shared the track with D1NZ
Cooling was fixed thanks to the new alloy radiator, never got over 82deg all day. Used the sprayers just because I could.
Was using 2 different brands of tyres now Horace have been bought out by Nankang - Hifly's and Kapsen's. Hifly's were the same as Hoeys, chunked a little but reasonable grip and smoked well. Kapsen's gripped a little less, smoked less and wore perfect and way slower - could get 2x sessions out of a pair as opposed to 1 out of the Hifly's.
A mate smashed off his winged sump and i collected a chunk of it with the BN sadly, so a little repair work needed there.
Am now planning the respray finally. It needs a compression dent and front guards fixed, along with a little rust around the sunroof. About a third of the car has already been resprayed so fingers crossed my painter won't sting me too much.
Have fixed the damage to the BN front and sideskirts with a fibreglass repair kit a mate got me. Surprisingly easy to work with and beefed up the lower lip while i was at it.
Have some loose plans for the interior as well: have bought some S15 rear seats to match the S15 front's it uses when on the road and am looking at dying the cloth on the door trims, glove box and headlining to suit the S15 seats. Finding factory plastic S13 boot trim panels is near on impossible so I'm going to make my own out of some bathroom paneling. Also looking at canards and sideskirt extensions for the Vertex road kit but will see how it looks after the respray
Baby is due 2nd of June so getting it resprayed and road legal by then is the goal, then drive it down to the Beginner/Amateur days i tutor at and take a pair of half-worns down and go for a sneaky skid to get my fix.
