Here is a huge update covering the last 3 months.
The manifold came with instructions to run the factory heat shield so I'm not sure you're going to see it which sucks. I booked the car in to get tuned and the only thing I need to find now is an air filter.
More boring parts photos.
One thing I have picked up recently which I'm super stoked on is a Bride Ergo2. I loved my Brix2 in the 180, I was initially put off by the graduation on the Ergo but I've since discovered the middle cushions and lower seat are very easy to remove, so they're going to get recovered in a black perforated fabric asap.
I think the Zeta3/Ergo2 combo should look awesome.
Nobody wants more headlight photos but I found a pair of LED fog lights, so I now have LED/HID/LED combo.
I found a good auto upholstery place in Auckland and took the seat out last week. I didn't spend too much time on picking the colour, I just went with what looked right.
When the fabric came in, it actually looked way better than the above photo!
& Done:
So yeah, that worked well! I'm dropping off the centre console for him and I'm tempted to do the centre cushions of the Zeta later on as well.
All the parts also got installed. Please excuse the excessive amount of blue, after getting everything in I've realised there is a lot I want to change so will go about getting some black silicon and a decent alloy overflow / catch can later on.
Trust Elbow bonus!
Car is tuned, no major issues which was nice, it made 275kw on 18psi which it made on the 4th pull, I can't remember the torque figure, I think it was somewhere in the early 400's.
We could have put more boost in after we hit our target number but the exhaust side of my setup is restricting the turbo, I would have to go to a 3.5" system to not stress it, this is mainly due to the internal wastegate also dumping into the exhaust - so there is a lot going through a 3" system right now.
I love my Kakimoto Exhaust.. it was the reason i bought the car, so I'm not changing it for now.. plus I am very nervous about my clutch at a higher power level.
I had a small fuel leak on the SARD Rail around the bung in the middle of the rail, I got that fixed the next weekend. I did drive it home and it's a totally different car, it's very linear where before it would kick then fall off.. it's definitely got more lag but the turbo holds 18psi from 4000 - 7500 and the power does not fall off it just keeps going up haha.
Have been driving the car a bit since it got tuned - it used a bit of oil on the dyno which I was worried about but I topped it up and no drama, it's not using any oil or water. I had some trouble with the cold start on the Haltech (NZ being in the middle of winter) but my tuner came out and did some adjustments and it's all good now.
I also installed some Serial Nine subframe and diff mounts, wow - what a huge difference, the rear end seems so much more predictable now.
June is the busiest time of year for me at work and now that we're through it's time to go drifting, have a few days booked in July.. can't wait. Here's a photo from a recent weekend at Hampton Downs, the Mark II on the left has the same turbo but 350kw
Finally someone took some good photos of this thing.. not much to update, haven't had a chance to go drifting yet due to no track days but took the opportunity to replace the warn Zestino's with some NS2R semi's up front.
Had the front balljoints replaced and a few annoying rattles dealt too as well. Car feels great at the moment, probably the best it's ever been.
