Update time.
So, drift prep. As per usual, we waited untill the week before Pembrey before panicking and trying to fix all the things that needed doing.
Firstly, I took the car down to M&M Engineering, so that Marshall could build me an exhaust and drop the seat down.
The exhaust is a full 2.5 inch stainless system, with a single oval Magnaflow backbox. It's also had the downpipes cut a bit so that it all sits above the chassis rails.
He also lowered the seat mount, dropped it about 2 inches. It's now the perfect height for me at 6 ft 6, still have headroom with my helmet on...
Next, stuck in some offset caster bushes, didn't get any good pics of them really.
Also, stuck the butch clutch in, once again, no good pics. Still drives nicely, not as heavy or jerky as I expected, which is great.
Finally, got the hubs modded again, so now I have a bit of front camber!
Finally, I got to hit the track. It was my first ever skid day (well, skid weekender). Learned so much over the weekend, went from barely being able to hold a drift, to sort of being able to transition and even managed to link two corners with a manji a couple of times!
Had a couple of teething problems throughout the weekend though. On the Saturday morning, everytime I went out on track it would cut out and not start after I span. Kept blowing the EFI fuse. Turns out, where the decat manifold is fitted, the standard lower lambda sensor sits very close to the firewall, and where I was doing big clutch kicks, the engine was rocking about and kept smashing the end of the sensor into the wall, which was causing the wires to short and blow the fuse. Luckily, I had a brand new lambda as I planned to replace it ages ago but never did, and the new one is shorter than the old smashed one, so that turned out to be quite an easy fix. Worth thinking about if you plan on fitting a decat mani to your is200 though!
On the Sunday, I suffered similar issues. Where the engine was rocking violently, it pulled on the wiring and snapped the plug on the VVT control valve. Unfortunately this was not repairable, so had to spend basically all day Sunday skidding with even less power than usual! I have since replaced the control valve, and am now on the lookout for some stiffer engine mounts as these seem to be the cause of all my problems...
Super excited to get back out on track again now. Got some pics from the on track photographers, cheers to them.
I did manage to knock my rear bumper off on one of the grass banks and broke all the mounting lugs, so just left it off for the rest of the day as it was only held by 2 cable ties and couldn't be arsed for it to fall off on the motorway etc. Drove home without it and fixed it in the week.
Got a cool pic of me and my RA bros waiting for jake's AA truck to pick him up.
Check out our fb page, Grants better at editing photos than I am so worth a look.
www.facebook.com/The.R.Alliance
Finally, some more updates on stuff I bought.
Got the Hyper Zeros powdercoated bronze, gonna be buying a set of the wider 9.5j ones and get them done the same colour. Liking them a lot.
Also bought an altezza rep grille, not sure if I want to use it, so will see how it looks on the car when it arrives. Looks like this.
