Sam's new Drift car. JDM haters stay away :)
looking good dude:thumbs: you fitting your steering couling back on then? good to see its all coming back together this is why you were a let down and not at lydd then yea???:dw:
you put spacers on or decent set of rims ??
Yup. I've been a big let down recently, most of the car has been living in my front room for ages!!!
Rears are Rota grid drifts, ET10, with a 25mm hubcentric spacer, and 10mm spacer as the standard studs came past the hubcentric spacers and wouldn't let the wheel sit flush.
so ET10, plus 25mm, plus 10mm. :( Little bit of camber makes up for it.
and yes, steering cowling is going back on. Last jobs are a couple more bolts in the steering wheel, and fit the snooper and road angel (for speed, as my speedo doesn't work :( )
my livery on too yer gayer..
but im freekin out about kill switch mounting/wiring.. and the tow bar/catch can.
I 'think' once they on Im at regs..
not even looked at engine or tyres or lock or a service or anything.. ouch
I think i'll service it before the weekend. Friday probably. I haven't changed the oil for 3 drift days, and 6 months.
hey man looks cool now still think you was overpriced by the cage thugh
out of curiousity what is the white boxs in the passanger side?
also im calling your car kit now as with all them doohickys it can blatently talk to you but can it time warp too?
The white boxes are the control boxes for the gauges. Proper pain in the arse, loads of wiring for them.
You do realise the kill switch is supposed to be fitted so you can't see most of it right? Should just be the key and slot you see, rather than the surround.
Function over form baby, function over form :thumbs:
Jack said:
ooh why is the glove box off, retrim perhaps.....
Nope. Fitting dash back, I removed the lower left glovebox bracket. Currently making an extension up.
Dori Mat said:
sam, is that one 52mm guage and two 60mm's in the dash vent panel ?
Correct :thumbs:
You big gay, it'd still function sunk into the dash.
Next dash, it's getting sunk. This one was a rush job getting it sorted for round 1.
Gonna buy another standard dash and make the measurements perfect this time.
Once I have time, I want to replace the entire loom on the car, this one was hacked about too many times by the previous jap owner for me to bother. Can't figure out why the RPM signal from the ecu doesn't work.
