Team 307 BDC build
Excellent work. Inspires me for my 13, I am someone with a motorsport background as well (although not competed). I am nearly fully stripped down ready to roll and weld up the underside. Keep up the good work :thumbs:
Thanks. u got a build page for that buddy? My only advice is trile fit everything!
After a weekend of fixing my arch mistake i finished up got the car back on its wheel and gave the chassie a clean. So a little late but i give you one rolling chassie
yea geo and ride hight need set proper but that will come! now have to trile fit this engine and new engine mounts
Any one else noticed japspeed parts are hard to get hold of at the moment??
trile fit one everything looks ok so far
will have to mark the sump for modification
Japspeed G box mount fitted ok
So far plenty of room. have to modify japspeed engine mounts. Engines quite low would like to keep it that way
cut the sump to allow fitment of the sway bar
Will extend the sump a bit to make up for what i have cut out and i hope to still fit a tomi baffel
Modifyed japspeed engine mounts
Fitted areomotive Y and also played with ware to fit the filter
Love the rear brakes. Its a good idea too. The Dragon RX8 has massive Porsche rear brakes and stock front ones for the same reason too- Handbrake is on the button every time at every speed.
i agree! you should be able to lock anywhere anytime! alot of people are starting to do this now! looks the tits! :smokin: good luck with it all! can't be long now until she is finished!
Ive seen them pop up on a few formula d cars so if they see the need for them i thought id give them a go, yes expensive but thought it might make my car stand out a bit
The kit takes a bit of fitting round the geo masters but dosn't need much modification. spaces out the back end a bit as well. Just have to order up all my lines and fittings to get it all plumbed in
Not a lot of guys running mega front brakes. Infact i have heard of guys having front brake failure and running a good run without front brakes. Still look cool though!!!
If it wasn't for my job and general life getting in the way it would be done by now also everythings a learning curb Even fitting the driftworks suspencion its not just a bolt on 5 minite job. I still have a lot to play with to get the lock i desire!. still a lot to do but i will get there. The expensive bit is coming up (engine turbo engine manigment) and i am waiting for a koyo radiator and a new intercooler so i can fab up the front end.
Ill be back on it this weekend so keep an eye out for up dates
Getting used to fitting and removing this engine
So far the sump mod works have a few ideas about moving the sway bar mounts forward a bit and using custom drop links to help
Going to fab up the front end this weekend !!!!
Thank you sir
Mr hat did that fix the problem?
No turned out it was bad wiring too the coil packs even though it had spark it obviously just wasn't powerfull enough lol but thanks so much for te help fella And good work what happened I thought the car was painted and now the fronts been hit with a grinder again
yea one step forward one step back i had to modify the front arches make them bigger for more lock!!!!!
It was no problem at all buddy glad to hear you have sorted it out
small update i did fab up part of the front end but ill put up pictures once i have the intercooler mounted and the radiator positioned.
Fitted the pedal box
Need to get the fuel system finished and the brake lines run so have a bit of ordering to do!!!
small update to show there still work on going! The bit i don't like about the build is project managment ie ordering parts in order or importance!!!
Had to sort out my fuel fittings order
I like when i get boxes like this thre the door!!!!
made a mistake with ordering the intercooler and radiator so once i get them hopfuly next week i can finsih the front end!!!
