I know most people don't have the time to read this thread from cover to cover but if you have the time it's well worth it
I'll let the JZ engine specialists recommend the oil feed setup, but to quickly cover off the other bits:
- You need a big oil drain that goes straight down. No AN fittings. I repeat, no AN fittings. If you can't find an off the shelf solution, get an oil drain flange and get a long piece of tubing welded on as big as you can fit and still access the oil drain bolts. Have the drain finish well clear of the manifold so you don't have to put any rubber hose close to the runners.
- Minimum 3" dump pipe off the turbo, but if you have the space (and you should being LHD) a 3.5" or 4" will see big gains in flow and boost control. Even just for the first couple of feet, but further ideally. You won't have to go far back through this thread to see what people have done as far as trimming the rear housing to fit V bands to the housing to free up the housing exit
- You'll have to consider an ECU as well, stock will throw it's toys out of the cot with the bigger injectors. I believe ECU Masters is big in Florida right now?
- Last thing is the things people tend to overlook: fresh water pump, timing belt & tensioner, oil cooler, bigger radiator, coilpacks - all things that tend to pop up when you start pushing an engine harder
