have you bled the slave ?
I know these sound like stupid questions but its easy to overlook things like this
I done a similar thing with my prop, but that big nut that bolts to the rear section used to slide down over time, it tightens up for rotational grip but seems to move forwards so I ended up welding it. Will probably end up going single piece over time.
Nice job man.
To test the master, undo the pipes and plug them with bolts.
Then press the pedal, if the pedal doesn't stay firm you know the master is fine
what I meant is the pedal would stay firm and not go to the floor doing it that way
I had what sounds like a similar issue with a mates 1uz. Issue was that the master cylinder doesn't move enough fluid to actuate the slave. Waiting on a bigger master turning up to solve the issue.
Have many people done this conversion can't say I've heard or seen any manual v8 soarers, as much as I love my manual one it's got to go I know I'll regret it after
Loads of folk have done it in the States and Oz, but over here they are few and far between.
This is the reason I hate concentric slaves, they can be a fucking pain and makes things harder to diagnose
