Is it then conceivable to use the NOS in the low rev range (when the car is bogging down) and then again at the very top of the revs to increase power at that point?
A note on NOS injected pre turbo/throttle body would also be good.
This will sound like sales BS but I must say it as it's 100% true; As long as you are using a correctly fitted WON system and following my exact instructions, yes it is certainly possible to use nitrous to do that. However, it would be EXTREMELY DANGEROUS (at worst) or TOTALLY INEFFECTUAL (at best), to try and do it with any other brand of nitrous kit.
As with my previous claim/s in a similar vein, I'm more than happy to provide a comprehensive technical explanation, as to why that is the case but as my time is very limited, for now at least I hope you guys will trust my 35 plus years of experience on such matters.
There isn't any functional difference (for the nitrous system itself), between injecting nitrous pre or post throttle body (TB) but there is more potential for negative consequences, from injecting pre TB if it's used incorrectly.
When it's designed, fitted and used correctly WON nitrous systems can and have been used safely and effectively on just about every combo that exists.
As with most aspects/subjects relating to nitrous, I could write at least a chapter (if not a full book) on it, but as time is so limited I can't do that for you just now. However, if you have a particular combo that you have a specific question about, I'd be more than happy to address that for you and I'll be able to do that, much sooner than posting a general response to your request.
I hope that helps some of you for now and I'll get back as soon as possible.
Thanks again for the positive posts.
