Doritofu
Active Member
Carrying on from last update, I've started working on the rear flare. Same process as with the front, get the inner line good first, making sure there is enough space for the wheel to move with suspension travel this time.
Then with the inner line done, do the outer line and then smooth out all the curves.
The rears are a proving to be much easier than the fronts as there is less going on, lining it up with the door jam has also made it a bit quicker to figure out the lines.
I've got enough of the rear done now to start seeing how they will look together.
While waiting for the filler to dry on the rear I have been slowly finalizing the front, getting all the low spots with guide coat and filling them in. I finally reached a good stage with it to give it the first layer of primer.
The main purpose was to put it on thick and get a uniform surface to bring to the final shape. The layer separations in the filler were sanding differently and I was ending up with a wood grain texture, the primer will help get rid of that.
Now that it's all one colour I could start marking out hardware placement and the additional line across the front where there would be an imaginary separation between the front bumper and front guard.
This line I'm just planning on carving into the flare so that it has the appearance of two separate pieces, but it will all be a single piece. This seems to be the way it's done and I think the extra detail will help.
I'm also nearly done with the bolt placements. The spacing at first seemed a little close, but it matches what other companies like Rocket Bunny and RWB are using. I still might space them out a little more.
From here the plan is to go over the front with some guide coat and try to finish the top surface. I'd also like to finish and prime the rear by the end of the week. Once they are done I'll lift the car all the way up and finish the underside of each of the guards and figure out how they will be mounted.
