Quick update on the progress over the past few days.
Got the tyres removed so that I could strip all the rust off the barrels and re-do them with etch primer and some epoxy enamel topcoat.
There was quite a lot of surface rust even on the tyre side of the barrel so that all had to come off with an aggressive wire wheel. After that they got a good clean, then scuffed for etch primer, then a final coat of silver over top to seal the primer.
I also drilled and tapped another 4 holes on the hubs for the aero covers to bolt to once they are done.
Speaking of aero covers. Since the first prototype was getting pretty dinged up I made another one using the straightest of the leftover pieces then gave it a thick coat of filler on the inside and filled the rest up with the leftover expanding foam. Waited for it to cure up then popped the metal form off to get this.
Even though it was the most circular out of all of them it still took a lot of sanding and measuring before it was good enough. Then I tested a few different designs on cad to figure out how deep I wanted the spacing and trimmed off the excess.
I used the same cad package to print off a drawing of the hub to get the layout of the holes on the mounting face perfectly spaced.
Then just spun up a little cap out of mdf to plug off the top, glued the whole thing down to a wooden base and primed it ready to be used for a mould to make all 4 aero-covers out of fiberglass.
I also got an early x-mas present in the form of my new Yoshimura badge. It's just personal preference but I much prefer the oldschool badge to the new one, so I swapped them over.
And the last thing. Finally time to start adding some more cyberpunk elements to the car. I took the spare oil cooler from my S13 and mocked up a fitment up front.
I planned to use the external cooler as part of the water cooling circuit for the electric motor swap. But now II will just fit a reservoir and pump in the engine bay, fill the clear hoses with coolant and then run electro luminescent wire inside the hoses. Hopefully it looks like the coolant is glowing. It will all tie in with the LED underglow that I will be adding at a later stage.
That will pretty much be all I get done before x-mas, so happy holidays everybody and I'll keep you up to date with any new progress.
