My RB27 Hcr32 t51r power!
looking shweeeet!! will pop up for that bracket soon one night mate sorry forgot to txt back I got a memory like a siv
WOOO got her mounted today! and got the breather hoses on and test fitted the coilpack vent!. She needs a good wash down and degrease now then i will stip it for paint and get all the hoses and pulleys and things on :)
Did a bit of cleaning to it today and also fitted up some more of the new silicone, just need to get a load of hose clips for it all!
Also fitted the water pump pully. And i have another nissan quest alternator to go on soon so will get that going on soon with the other pulleys.
Pics :D
And my side exit screamer :P
top quality build!! just one thing is bugging me.. please dont recover your door cards in bride fabric if you dont have genuine bride seats!! im not digging i really like your build so far and will be top notch with your new rims.. i just think it will kill your car if you lay that fabric down kinda like how you were worryed about the nismo badge being takky(i just sat down for 2 hours and read ur hole thread=P)
its just my oppinion so dont take it to heart im excyted to see how this 32 turns out!
Well my door cards are peeling right now so I wanted to freshen them up and match them in with the seats! And yeah they arnt real brides atm but that could change and at a glance you won't notice they arnt the same. The fabric matches the seats fully and I was going to get a nice leather cover with red stitching to go on the rears to tidy that all in with it and some cool Jdm mats will freshen it up nicely I would say :) it probs won't be to everyones taste but im sure it will look nice. If it doesn't I can change it easily enough for some carbon. Glad you like the rest of it though. Can't wait to finish her! :)
Right does anyone know what the widest wheels I can fit on my 32 with the ep racing front +25mm and +20mm fenders on? I know 9.5 et12 and 10 et 12 will fit but I want to go wider! Say 18x10 et35 or 12 if poss 245 35 front and 18x12 et 20 265 35? What ate the chances that will fit with a bit of camber and the lips taken off the overfenders?
18x9,5 ET -8 on stock fenders, about 30mm space between lip and fender. Whit 18x10 you may have problem whit arms and inner fenders on front.
18x9,5 ET -8 would fit nicely whit +20mm fenders on front in my opinion.
18x12 ET 20 wont fit on behind, ET 10 may fit. Same problem whit this, hicas arm and inner fenders are on your way.
and whit 18x12 ET 0/10 you may need some more overfender then +25mm :D
heres picture whit ET 0
Well the dw staff say the 12 et 20 clears the arms on a 32 will have to have a measure up. Are your rear et0 the 12j gtr-d? I would like to run 9.5 et 12 front and the 12 rear. Thanks for the pics looks awesome!
I cant belive that because I've tested whit 18x12 et20 on rear and its like 5mm what you need to pass the hicas arm. Whit DW hicas lock it may fit whitout a problem?
18x12 et20 whit 20mm spacer, so it's like 18x12 et0 :) Np!
ah cool!! So does it hit your arms without the spacer? Are U running stock arms still? As im using all dw arms so that are a bit smaller and have the hicas removed. I have also measured from my wheel to the outer edge of the over fender and I have like 4mm of room spare but that's on the outside of the fender lol! Maybe I could space the fender out a bit to help.
Yes, stock arms on rear. Problem is that stock? hicas arm on the picture.
When this problem is solved, next could be inner fenders when you're going reaaalllyy low, not sure about this.
Yeah that's stock the dw hicas removal kit cuts that right down as it clamps either side of the hub so its only about 10mm either side or so.
Hmmm very tempting to try fit the 12s now haha! Gonna try get a 50mm spacer and see if I can get my arches to fit! Thanks for the help
Right thanks to dirty-diesel i have tried on some 45mm spacers with my wheels running 8.5 et22 so that sould make it basically the same as the 12 et20! :D and here is the results!!
Thoughts? :D
