My RB27 Hcr32 t51r power!
a slight setback today well last night after dropping the gf off lol. one of the small coolant pipes under the inlet mani decided to split! so today i got the old one off and replaced it with a new bit of 3 ply slicone pipe :) so all is well again!
get yourself some parts from japspeed to get it breathing well and to keep it cool. so get a full exhaist system a nice large fmic and ally rad then get rid of the old stock bushes and arms and if you can get a set of the driftworks stuff! and dont forget the coilovers!
with a remap and things like a nice induction kit and fmic and full exhaust you should see close to 300. then drop a hybrid turbo and some 555 injectors and cams and a metal headgasket and your looking at about 350-380. any more than that and your going to want to upgrade the water pump , oil pump. acl bearings and some forged rods and pistons and a head drain kit! and that should be good for over 400+. probs easier to just drop a rb26 in though lol!
Right after finding a leak in the rad i have taken it out and found out it the the drain plug rubber had split!
as you can see it was shot! but as i couldnt find a replacement rubber i decided to find a bolt to replace it and found one in halfords! it was a sump plug!
Then thanks to mitto bled it using his bottle trick!
So all is well again!
time for a bit of an update!
Been shopping again!!
and a nice adjustable fpr to go with my walbro 255 pump
Thats about it for now as im still waiting on some aero to comeback in stock ;)
thanks v-con! i already have the other suspension parts replaced on the car with dw parts these are the remaiding ones so yeah gonna get busy when i have some time off work and get fitting!
**update time**
Right the skybus is going up to rk tuning on monday to get all of the suspension parts and the hicas removal kit fitted! GOOD TIMES! i would do it my self but im mega busy with work and have not got any time free at all atm! i also have this lot to go on aswell!!
Competition stage 4 clutch and 4.6kg flywheel...mmmmm
This is also getting fitted at RK on monday.
A new slimline (25mm thick) snapoff boss!
I also got me a nice Nistune ecu to drop in!
And the reason i got the snap off!
Also to add i nw have all of my new aero and im just waiting for my new wheels to come back in stock and then i will get the ball rolling on the bodywork! ;) and im also going to pay steve at tc tuning a visit to get the nistune a remap once my new fuel pump and frp goes in.
And i got this little guage to replace the one on the fpr as it doesnt fit very well
That is all for now.
im also very tempted by a nice spec rb25 with a rather nice topmount and a few other goodies to drop in seeing as i was planning on putting something bigger in. hmmm best go talk to the bank manager!
right just on my way home now after dropping the car off at RK to have all the clutch and suspension parts put on! cant wait to get her back!
right update time! clutch and all the suspension is on!
and then thanks to mat i now have these bits to put on!
good times!
