Home time. I had a few things to tick off my list so it was time to get stuck into it.
First job was to plumb up the hydraulic handbrake.
Got onto routing the lines. I chose to route them underneath the car for a cleaner look.
I drilled a hole for the line to route through. Use a grommet so the line doesn't rub anywhere.
Gk tech supplied these isolation clamps in their kit which were very handy. I used one to clamp the line down before the grommet. It was bolted down using riv nuts.
I didn't get any pics from underneath. It's quite simple just run the line to the calipers and use the supplied isolation clamps to secure it to the chassis.
Since I have a fuel tank in the boot now the factory one isn't needed. To remove this it's quite simple. Remove the subframe and disconnect everything connected to the tank. There will be lines from the fuel filler side running to the tank so these will need to be removed. After everything us undone it's just a matter of un bolting the two straps and down it comes.
With the tank gone there was a massive patch left where I hadn't undersealed. Although no one would ever see this couldn't stay like this thanks to my OCD Haha so it was re coated.
Up next was the dashes turn. I had already modified it to fit with the rollcage but the bottom of the stereo surround needed to be trimmed to suit the position of the hydraulic handbrake.
Dash went back in to see how much needed to be trimmed from the lower half.
Slowly trimmed until it fit
Fitting quite nicely now
Centre console and shifter surround bolted in. Loving how it's looking, makes me want to drive it. All I can do is sit it for now lol.
While the subframe was out it was the perfect time to change the axle bolts. The ones that the wreckers gave me were obviously too short so I ordered some new hardware from Nissan.
Genuine Nissan bolts, nuts and washers
Old vs new
Much better
The boot needed a coat of paint do I decided to match the interior colour and go for a satin black. Everything was masked and prepped for paint
Primer done
Underneath as well
Looking much better
