Team 307 BDC build
Finished pedal box and bias adjuster really happy how it s turned out
Got a front screen fitted
brakes + hand brake all blead
Just waitning on a few more parts now to finish off!
An un expected addition but here is the knock link ive been waiting for and am in the process of wiring in. Link G4 storm does not take direct knock signal the signal needs to be amplifyed. Apparently the knock sensor frequency in the rb26 is 6.7Khz if anyone is interested
This gives me a knock window in the Link G4 ecu I can moniter and control knock over a six cylinders! Apparently!
Handy link http://www.skylinesaustralia.com/forums/topic/328859-knock-sensor-starting-points-for-monitoring/
Think my idle problems are to do with how ive got the idle solonoid set up on the ecu the engine is running so ritch its not burning the fuel.
Anyway fired it up and kept it up above 2000 and its running smooth. 50% master trim on the fuel so you can imagine 600cc injectors 50% of that 300CC close to the standard injectors.
Any way think ive got it sussed just needs maped properly.
So what do you think?
GKtech mirrors
carbon boot skin for srb power aparently 3KG! feals like it
fitted with aero catches
Bonnet aero catches
The bootlid just needs a bracket the push the back out a bit to align lights up and itl be sorted
thanks for all the good feedback
Sherman? im guessing thats u douglas???
Its getting close to finished and getting very excited made the final changes to the oil system and sway bar brackets to clear the low mounted rb26
Acusump
works really well just wish id planed it into the build at the start
Run out of time today but i will get the seats finaly mounted next
i'm waiting on the windows next there are 4 week lead time should be next week fingers crosed. Need a camber gauge to set suspencion and rolling road is booked for next month.
big push this weekend to get the plastic windows fitted, just avbout finished
Ended up with an alloy angle support realy helps stiffen the over flexable door. and i mage a tube support to hold the plastic window. The window still needs support at the top and i need to make door cards.
GKteck wing mirrors fit spot on
Windows!!!!!!!!!!!!!
so this is ware were at
Its getting mapped next week so hope to be completed vry soon fingers crossed all goes well next week!!!
Few lil bits to finish off but we are getting there:)
looks great dude this build is so epic its unreal. im doing lexan glass on my front windows. how is that attached in any better pictures. love the door cars mine should be going like that. have you just used an aluminum sheet and bent the edge over at the top to give a smooth finish.
thanks
