Now that i'm back on my feet i'v been cracking into the build up.
First off was to get the car back on its feet, the rolling shell was built up.
The suspension and subframes installed, all striped painted and refurbed.
I welded bracing on all the pickup point on the subframe and a tie bar between the toe rods.
Needs alignment next.
Ordered some Powered by max steering rods. May need to lengthen them to cope with the extended arms. They look like good bits of kit with the 7mm spacer built into it. Might turn some more off and run a spacer to make it up to 13mm one side. Then recentre the rack.
POWERED BY MAX: ??????????up Super Steering Angle Parts
Engine bay ready for engine.
Interior back together, just need to run fuel lines, the std steel ones were rotten so thought it safe to replace them with braided.
Clean painted boot
Took it back up home to install the engine and fab the downpipe and ic pipework. Raised the rear coilovers for clearance in and out my garage. It will be decked once its done.
Removed some of the stickers to give it more of a clean look. Gave it a bit of a polish, amazed how polish removes the marks and tidys up the used paint work.
Until another day
