diamondsink
Kyouto Drift
So today was a good day, GOT THE THING RUNNING!
Done a final fit of the turbo and plumbed everything up. Had to stick the old afm on as its still running on the old map with 555s. I will change it before it goes to Greg.
Fitted a new oil pressure gauge, then cranked it over to get the pressure up. Had to wire a direct 12v feed to the gauge as it goes off normally on the old stereo 12v feed when cranking.
Took about 20 secs of cranking to get some pressure but then it shot to 3 bar. Chucked some fuel in and went for the start.
Started straight up with good oil pressure.
Also had to extended my standard modded arms as my Powered by max ones are delayed. Extended 40mm.
