the lock thread
not quite full lock, but not miles away from it.
Upper & lower arms extended 40mm each side, pitman arm & Idler arm wxtended 20mm (no hub mods done yet)
Jono
Geomasters of course :D
with raised front (35mm) and rear (25mm) subframes, home made front arms, ikeya formula tierods, 9j et5 equip with 215 40 17 toyo proxes. s13 apex gen1 10/8 coilies. godspeed s13 roll bars. modified s14 rear subframe.
I extended S14 lower arms a further 20mm. Moved my rack forward, modified my hubs and extended my track rods. First thing to hit now is the brake disks on the lower arms. Next job will be to make some lower arms and more extreme knuckles.
A pic from NDC, this won't be full lock but it's all I got:
dunkx you have a couple options.
1. you can grind away a little bit of the lower arm lip
2. you use a 5mm slip on spacer between the brake disc and the hub and then space out the caliper (you may need big brake kit to be able to space the caliper out)
alternatively you can do what you say and make new arms entirely lol
Yeah, I've already ground a chunk out. Got a 330mm brake kit On the car. I did consider changing the caliper spaces to push it out but I'd rather just make some lower arms. I'll integrate my tension rod into it aswell whilst I'm at it. Will need to try running without the Arb and see how it feels as that will be the next limit.
Custom arms is defo the way to go!
Ive been running with no arbs for a long time. Iam actually going to reduce lock and fit a front bar again because i want to see if it makes a positive difference. ill soon see if i miss the lock :)
Apex coilovers
DW LCA's with Lock stops removed
DW tension rods
JapSpeed tie rods/arms no extra spacers.
Standard knuckles for now
GodSpeed ARB's
17X9.75J et15 including spacer
-5* camber, 0 toe, 7*caster
Billy that is only doing half a job !
you need to post up how you got that lock ;) .. then that will remind me what i need to do :D
Right!
Modified Knuckles,
Lengthened Tein tie rods,
S14 arms lengthened 20mm and notched,
Rack moved forward,
Offset tension rod bushes,
Cut/bash anything else that is in the way.
Yeah I saw that, deffo interesting! Better than Geomasters you think?
Phil has also metioned the possibility of R-chassis Geomaster too! :D
I personally reckon that its likely that they pretty much just copied a geomaster to make sbody knuckles. But they have the interchangeable caliper mounts and steering arms which i find interesting :D the rears will have spherical bearings and twin caliper mounts which i also find interesting :D
