The R32 Chronicles
So went to the unit and did a seat rail test fit.
That didnt even slightly work. Too far forward,
And too high. Way too close to the cage unless i want a concussion every time i hit a bump. Fuck that.
So i posted the rail up for sale and a mate picked it up within an hour for more than i paid for it. Mint.
Onto plan B. Balls to having it on runners. Its my car, so im going to put the seat where i want it. If anyone else drives it. Its their problem. Fucking lucky im even letting them drive it.
Plan B ordered haha.
So i then went and gave Ed a hand on his s14 shell prep. We finished off all the repair work on his shell and then made more room for fitment to happen.
So we marked it up and took a grinder too Eds mint upper chassis rail. So we chopped what needed to go.
Then we welded 3mm into the upper chassis rail and made room for activities.
Jobs a goodun.
Also some more parts arrived. This time from Australia.
Poly engine mounts F.T tuna chunks.
So no car progess but.
Kind of taken over the house with boxes. Nothing massive lots of little bits. But the seat mounts are here. Some primer to do some bits. A gearbox mount.
A rb25de throttle body which is slightly larger than the det throttle bodies, however i refuse to hand over £200 plus for a Q45.
Also had another delivery
A nice OBP 1.5l swirl pot with an fittings. So that should make for a nice install and another piece of the puzzle.
So i got my arms back from my old man after he pressed in the new ball joints and bushes for me.
Also in other news I’ve bought a turbo. From the start i wanted a GTX3076 gen2 however this came up at a grand less than a new garret and this has done next to no miles. Its a bernie blowers hybrid gt3076 with a gtx compressor wheel, on a 0.64ar rear housing so should come on nice and early.
So i should have that soon.
So i booked Ed a hotel and we had a 2 dayer on the car this weekend just gone. Hit it hard and put around 55 man hours into it over the 2 days. Which made a nice step in the right direction. I unfortunately didnt take millons of photos because i was more set on making progress. So whilst Ed set to work re making the rear pockect and rear tub. I set to work putting the gussets into the cage.
Trimmed everything and marked my welds up. I was nervous about this because they are probably some of the most seen welds on the cage so i wanted them too look as nice as they could with a MIG so i did some practice welds to get the welder set on some spare tube and a spare gusset.
Once i was happy i welded the gusset into the car.
It came out ok so i repeated the same on the other side then chucked some primer over them both.
So that was 1 job ticked off.
Whilst i was welding these in Ed had cut some pannels for the rear and was waiting for the welder so made a start on removing the old tubs i did ages ago, too small, like a twat, that i am still not over haha.
So i chucked him the welder and finished cutting the tubs out myself.
In the fucking bin. Pieces of shit.
Once Ed had the rear tacked up i set to welding whilst he finished the tidying up of the front tub removal.
Then i treated it all with magic anti rust and aids potion, primered it and called it another job done.
Excellent. Then i started on what i thought would be the quick job of mounting up seats. I chopped the standard seat mount out. Then Chucked a side mount onto the seat. Then bolted the weld on brackets onto them and dropped it in the car.
After a lot of head scratching and figuring put we managed to get some tacks on some things so i could actually sit in it an get the seat where i wanted. After a bit more head scratching and 3 hours of my life im never getting back it was welded into the car.
What a pain in the dick that was. So we decided we had had enough and went to the hotel
The state of the unit when we left should give you a rough idea of the day we had haha.
Onto day 2. First things first. We got IDC on the ipad linked to the sound system in the unit for entertainment for the day.
I set to work mounting up the passenger seat whilst Ed started remaking the front tubs.
I quickly realised that due to the exhaust tunnel on the passenger side of the car i was going to struggle to mount the passenger side the same way as the driver side. Thats when i rememberd my friend Ash had a basemount bride seat mount in his garage a mile away from my unit. So i got him to bring it up. I bolted it in and sat the seat ontop and it was going to work mint. I just had to modify the skinny boy bride mount to take my fat fuck seats.
Its a bit agricultural but it works. I cut 2 wide pieces of 4mm, mounted it to the seat. Dropped that ontop of the rail bolted into the car. Tacked it on. Took it all out and welded it up fully.
Nice and hot and solid. I chucked some primer and matt black over it, almost looked factory, if you squint.
But i mounted the passenger side in a reasonable place so that was good.
Meanwhile Ed had pretty much got 1 tub all tacked up.
Much more intelligent sized. It looks so much better than the mk1 aids i welded in originally. So we made and end pannel and i set to work welding it up whilst Ed started on the drivers side.
They still need dressing back but they take a surprising amount of time to weld in nicely.
Ed had got the drivers side starting to look like a tub.
Then he asked me to tack some bits in from under the car. It was at this point i started to realise Ed is sick of my poor life choices.
So we got an end pannel tacked in and Ed headed home after 2 days of being a fuckimg hero and i stayed and welded up the drivers side tub.
As i started welding the top i ran out of gas so i need to go back and finish the welding.
We have made the pannels bigger to make welding easier. Obviously it all needs dressing and trimming up.
So i put some primer on the tubs, tidied up the workshop and took some photos for the Gram haha.
I am so pleased with what we got done this weekend. Yet again a massive thanks to Ed and his dedication in helping me with this car.
We genuinely only have probably 2-3 more days of welding. To do. Just need to do the tubs between the strut and the fire wall. Then the chassis rails, then the welding will be done.
I am starting to see light at the end of the tunnel with the welding. Especially as the car is starting to resemble a preped shell. So happy.
Thanks for taking the time to read my drivel. Also thank you to everyone for the feedback so far. Its really appreciate.
Please to see another update on this mate! Looking like a properly prepped 32 now - Can't wait for pretty things to start going back on!
So as i said previously. The car is booked in for mapping at the end of April. So that means i need to regulary work on the car.
I finished up welding the tubs in. I then cleaned up welds, trimmed up the back edges of the tubs up and primed everything.
Really pleased with how they look.
Then the worlds snazziest DHL vehicle turned up.
You may of seen Darrens build thread on here. If not I advise you go take a look. Its a stunner.
On his way to me he snapped his exhaust hanger. So he jacked it up and i welded it up. Whilst it was in the air. Be rude not too try my ssr’s on it.
They need smaller tyres. But fit.
The reason Darren came to see me wasn’t only to make me jealous because his car works and mine doesnt, but he also was bringing me a turbo.
My new Garry gt3076r with a billet gtx shaft and compressor wheel with a 0.64ar t3 rear housing. It wasn’t actually built by garry. It was built by Bernie at Bernies blowers.
Marvellous. Thanks to Darren for bringing it to me.
Next onto the bullshit job of between the strut and the firewall. Now as with just about everything on this car. This job ended up taking me way longer than I anticipated.
So this is what it look like before. Rusty and awful and you can see the seam to the firewall was rotten.
So out with the grinder.
This was where it then got tricky, i needed to bend a piece of sheet 65 differnt ways at the same time. So i roughly cut and tacked a piece in.
Then realised after a lot of pushing and pulling and a degree of swearing, i dont have the tools, skills or paitence to make it
Out of 1 pannel. I then failed to take any photos of figuring that out, nor can I explain how irritatingly long it took to get this figured out. Here is a photo of it all welded up.
Its not the prettiest, however it could of looked a lot worse. So i threw some primer on it and that was my day done.
I now have a plan for how im going to the otherside next week which should be a bit easier. Then its onto chassis rails. We are chipping away bit by bit.
So i had another productive Friday evening on the car again. I went down with the intention of getting the other firewall to strut tower tub sorted.
I got there had a look at realised it didnt need to fully come out the tub wasn’t rotten just the seam on the firewall itself. So not one for making anymore work for myself. I hatched a plan. Fired up the heat gun and a scraper and fished as much of the seam sealer out the join between the firewall and the tub on the bay side.
Got it fished out and laid a questionable but effective weld in the gap.
Not the prettiest but does the job.
Then i went on the wheel arch side of the tub and started to clean the flange up that creates the seam onto the firewall.
It looked like shit so kept cleaning it up. Ended up with this.
I forgot to take photos but i treated it magic potion and put some epoxy primer on it.
This went way better than I anticipated so i set to work on another part of the car ive been putting off. The chassis rail to inner wheel well. Mine had some unpleasant blisters that needed sorting.
So i commited and thew a cutting disk threw it out and figured it out from there on.
My plan was to try and get it out in 1 bit so
I can use it as a template. Then quickly realised there was spot welds holding it in and more layers than I anticipated. So
I drilled some spot welds out.
Fought it for about 10 minutes trying to get it out nicely.
Fucking nailed it.
What greeted me behind was pretty disgusting.
So i took to cleaning it up and seeing if it was saveable or if i needed to cut more out.
Turns out it was saveable. So i dressed it flat again. Then treated it with some magic potion.
Then set too making a new pannel. Used the old one as a template.
Sketched it onto some 1mm.
Tried it into the hole.
Fucking nailed it. Fitted near enough first time. So i roughed out where the flange was so i could drill some holes to plug weld to the other flange. So i drilled some holes and checked it was in the correct place.
I magic potioned the back of the plate i was putting in so it wasnt bare metal.
Then i tacked it in.
Then i welded it in fully.
Not bad. I was on a mother fucking roll. So i decided to start the other side.
I made a hole.
Cleaned everything up. Magic potioned it. Once that had dried i epoxy primered it like
I had done the other side.
I then made a new pannel after using the part i cut out as a template again the same as i did on the other side. Marked out the holes for the plug welds, and then magic potioned the inside.
It then got tacked in and i checked i was happy with everything.
I then welded it up fully.
I then magic potioned both sides.
Once that had dried i then primered it too.
So these were the last of the welding jobs i was really worried about and thought were going to be massively involved.
Turned out i made the skyline my bitch and had a properly productive evening on it and made way more progress than i was expecting. So i am massively pleased with that. This means all that remains of the welding is the chassis rails. I am not worried about those. They should be pretty straight forward.
So thats another update. As promised they are fairly regularly now i am working on the car weekly. This means there should be more updates soon.
Thank you once again for taking the time to read my drivel.
So my team mate Adams engine bay is coming together lovely and makes me happy because mine shouldnt look too dissimilar.
His engine should make a little more power than mine because its an rb25det neo with headgasket and studs whereas mine is just a spec 2 rb25 with headgasket and studs so wont be able to run quite the same boost as Adam. A gtx3076r, 6 boost and a freddy inlet with a q45 throttle body all managed by Link. Should be enough to party.
Now Adam has also been a fucking hero because compleatly unbeknown to me. He spent his day off work working on my car. He has been doing the shitty job of finishing the bay, seam sealing everything, fillering the bay and smoothing it all off ready for paint. A shit time consuming job and it was a great supprise when he sent me the photos. I have some rad friends helping me with this car.
All seam sealered from the back. So the messier side is in the wheel arch.
Then in the bay he has been pretty handy with the grinder and then the filler making it looks sick.
Tubs looking sick.
The strut to firewall side of the tub has all been fillered and smoothed in and looks pretty dam good considering.
He then primered all his work in the bay.
Looks fucking awesome. Im well chuffed. He then went one step further and tidied the workshop. Chucked some headlights in my car for motivation purposes.
There was a huge pile of rust and offcuts under the boot. What a guy.
Then the last photo he sent me was fucking motivational as fuck. He placed my ssr’s up roughly in place.
That is the most car like this thing has looked for about 2 years. And it has excitied me no end. It looks fucking sick. What do you guys think?
There is not much more welding to do before this can get stripped and undersealed ready to go back on the floor. Im hoping this side of christmas.
Also do you guys read this thread at all. I’ve not seen much in the way of replies. So just curious to see if people are enjoying it or i am waffling away to myself.
I mean im not going to stop doing it. I was just curious.
Thanks guys.
I re-iterate - this thread is the only reason I signed up to the forum! The mock up with the wheels looks sick! Driving on its own steam by January?!
