So, current plan of attack is to completely replace the main harness loom that runs from the d/s fuse box to the wiper motors. The way the existing loom had be tucked meant that it would be a simple unplug and replace job, as he spent alot of time cutting and tucking the loom inside the arch to prevent any rubbing issues. My plan of attack would now to either do the same, cut and solder each wire inside the the arch, or to do something that is slowly becoming more popular, which is to relocate the fuseboxes inside and extend the necessary wiring.
Now I chose the latter, and seeing as I dont run the headlight motors that means I can remove a fair amount of wiring too
Began by removing the untouched harness from my old 13;
Whilst I waited for my friend to come and help me with my wiring as he's much much better at it than me, I decided to remove the tension rod brackets as one was dented fairly badly. But as with everything, bad luck continued and the captive nut broke free inside the chassis leg.
There was only one option left, and out came the grinder;
The offending captive nut haha. Wasn't too bad with an empty engine bay, removed the other 3 bolts and span the bracket round and could easily just slice between the chassis leg and the bracket.
Quickly whipped my old front ARB off whilst I was as it
Decided to call it a day after doing a few small odd jobs here and there.
So, the next day I went back to the car with a fresh head and removed the dash and unplugged the harness I'm replacing. Found a few of the heater matrix boxes loose so spent a bit of time making all of them secure, to try and avoid those annoying rattles they might make in the future. Whilst I was under the dash, I quickly popped my old clutch pedal off the 13 and loosely bolted it into the Silvia just to try and make it feel like a normal car haha.
Annoyingly the car had a hydro bracket welded to the tunnel. Now, I'll be running a hydro in this car but planning on a much different setup so this needed to go.
So out came the grinder and slit it down the welds, may have made one cut a bit too big, but nothing that can't be fixed whilst repairing the 2 holes left by rusty welds.
Decided to have a quick break, aka grab a drink and something to eat, and threw my front wheels on with a 25mm spacer off the rear as I'm planning on running this setup. Looks pretty aggressive, but with a shade more camber and wider front wings it should look spot on and match the look I'm going for.
Whilst I had the tension rod brackets off, it'd be rude not to try and make them look a bit better than rusty old nissan metal. So a quick wire brush and a tad bit of sanding and they were ready for some zinc primer.
I had my bare subframe off the 13 ready to get cleaned up too, so more wire brushing and sanding and it was in a semi-decent state. The reason not for splashing/wasting money on fancy powder coating is purely because I just wanted to make them clean as its a happier place to work on if that makes sense, plus with some plans that i'll soon to reveal id rather spend the money on somewhere that counts :smoking:
Following this, I had two mates pop over, Tippers and Ian and began by staring at my front arches
Didn't take long for them to convince me to get the grinder out so Tippers said goodbye to them in a true fashion;
Plus, this gives me the chance to make sure the engine bay is nice and tidy, and due to the PBM High Mount Intercooler, I dont need the unnecessary holes for a FMIC by the previous owners. Even though this car will be used hard, it wont stop me making sure the car is as presentable as I can make it
Whilst me and Tippers had a look and began chopping my loom around, I handed a Ian the grinder and before I knew it, it was like this!
Dreamer spec lock y0!
We were discussing the route we are going to tub my arches, and we have tried to cut along the seam lines in order to try and keep as much strength along the arches as possible. Although, the excess metal left of the struts will be removed once the arches are here. Measure twice and cut once and all that
Quickly chucked a bit of Hammerite on the rear subframe and didn't come out too bad in my opinion, for something that you wont see anyway
Keep finding small little problems with the shell, like the ignition barrel can be moved with a screwdriver
So more inconvientant things that need to be sorted. The new loom kept blowing the Alternator fuse too, but we've put it down to dodgy earths and now doesn't blow it. However, the starter isn't getting the correct voltage so theres still a problem somewhere, BUT most importantly the Digital Climate Control and power windows work so power is getting through the rest of the system just fine
Onwards and upwards!
