Clive
Active Member
FFS Kam stop telling people the drums brake fit straight on!
Shit like that is the reason why I got fucking stranded down my workshop VERY late!!
Ok, rant over, its simple to sort... Some old drive shafts nuts and washers work great as spacers.... IF you already knew about this and had them too hand!! Dw already knew about this issue before I advised....... So should say it on a bit of paper in the box or something instead of keep telling people the drum brakes 'fit straight on!'
Oh and people, just a note, if fitting to a s14/s14a/s15 you NEED the nuts from a s13 that retain the rear shocks! Again, people should be advised about this imo!!
Now that's out the way, they are completely awesome, with the roll centre correction, car drives lovely on them, even more noticable when just driving about on the roads low speed cornering and parking etc feels a bit strange, but just like a welded diff... You get used to it after time
Quicker steering with near on zero effort with the wheel..! Mental lock can be gained, far more then ill ever need at my skill level!
Oh, since fitting them, I have not been able to get the stock drum brake to lock the rears... No matter what I do... I believe this is down to the cables since swapping them.hard to explain.... And on that note, you swap the backing plates and cables... Just remove the cables, backing plates shoes mech etc as an assembly, will save you loads of time and pissing about with springs lol
Also, to save time... Prep the geos' before fitting... Small round file required to get all the unwanted powder coating out the bolt holes, where the rear hubs fit etc...
Also I had to take a bit of sand paper to the front splines to get the hubs on! Better then them being loose thou not sure if others have/will have... But worthraking into consideration.
