Fruitbooter
Little update -
Continued working on the underneath and got it to a point where I’m happy to paint.
There were slight areas that were an absolute bas*ard to get 100% clean.
This bit for example was worked on for ages, in the end I got rid of as much as I can and then decided to paint as you can apply the primer with up to 10% rust present anyway. Btw I got it looking much better than the above pic before I painted.
The underneath then looked like this after 2 coats of electrox -
I’m annoyed about the above box rail being damaged as this was done before I bought the car
can’t really repair this without cutting it out and welding a new bit in place...
I put the bits that need plating in a solution of Deox C
Its fast acting and after about 8 hours they looked like this -
I will do it again the day before I take them to be plated.
I then went about seam sealing -
Not the best looking jobs but it’s going to be painted over anyway so you shouldn’t be able to see it.
Atm I’m working on prepping the prop and diff etc. for paint, and I will also put the top coat of protection on the underside when I can. Not sure whether to do stone chip on top of that also so there is 3 layers of protection...
